Here a Print wich uses the “Spiral Vase” feature!
Just some Issues with fine strings from the PLA.
Very nice
What was the print time?
How much plastic?
print time about 7 Hours with normal Speed.
PLA 10618.3mm (75.1cm3)
We also printed this one to test the spiral vase feature, what a coincidence
I printed in black so it’s not that cool though. You can raise the speed to 150% (feedrate) with no problem on this one.
I have to agree the spiral vase feature is nice. Especially with half transparent PLA.
motoritz: Interresting fan nozzle you have there! Is it on thingiverse?
Wow,
Very nice.
I have to ask.
Where did you get the design for the fan nozzle and the LEDS.
Very nice features.
The fan nozzle is from thingiverse indeed. http://www.thingiverse.com/thing:108972 I’m not quite satisfied with it yet. It’s a little too long and starts vibrating easily…
The led light is a flexible led strip ( sold as day light for cars ) tied to the extruder with cable ties I can try make another picture of it when my current print is done.
Here it is:
Wraps around the extruder like it was made for this.
Very nice.
Thanks for the information.
Spiral Vase Feature?
Pardon my ignorance… but what is the spiral vase feature?
Repetier Slicer tab on the right Configure --> Printer Settings
[quote=“Wrong Way”]Hi,
Repetier Slicer tab on the right Configure --> Printer Settings[/quote]
What exactly does that change?
I never used it before.
If you float your mouse pointer over the check box it should tell you.
X(
sould have seen that myself
If i get it right this improves print quality on thin wall objects right?
