Hello hello, I recently purchased a vertex nano 3D printer. The printer is working but makes a lot of unnecessary noise. Especially the fan on the printhead. In addition, I noticed that the selection button only works occasionally, which means that you have to scroll several times without movement before you can make a selection. Can this be solved?
Extra update: As I was printing both nuts on the Y-axis got loose, seems weird to me since it was an assembled version. Result is a burned out hole in my printer sticker and no idea how to get the nuts back in place. To add to that the motor used for the Y-axis is loosely mounted as well and makes noise every time it turns. As I mentioned before. This was a pre-assembled printer. Is there any possibility I can send this back for a warranty check? Thanks.
Jonas
