Build your own low-cost system for creating sound and light shows, using the new AREMBE Audacity software to control Velleman K8055/K8055N/VM110/VM110N USB Experiment Interface Boards. No complex programming is required. Simply import or create a music track, select which outputs you want to switch on at each step, and then synchronise the steps by adding a label for each step to an Audacity Label Track.
Find out more at www.arembe.com
