Hello!
I am upgrading to a heated bed. But I wonder if I can replace the stock power supply with a 12 volt 30 ampere one. I don’t really like the idea of having two separate power supplies.
Thanks in advance
Hello!
Thanks in advance
If you want to use only one PSU use a 15V 500W one. You can feed the bed through a SSR or a power expander.
I’ve got a 24V at home and want to use it to power my mainboard.
Wich converter do i have to use?
Unfortunately there is no simple way of using a single 24V power supply. The motherboard can take max up to 18V, if you want to use 24V you need to modify the board.
See here : http://forum.velleman.eu/viewtopic.php?f=59&t=18236
Yes, I think that this investions were really interesting
I use a second power supply in the assumption that
I am using a mechanical relay instead of a SSR in order to have minimal loss and have had no issue so far (12 months)
