New printer, no motors working, everything else functional
Built it and had no issues until it came to manually controlling the machine. It refuses to respond to any type of XYZ/E input.
However I can heat the bed and extruder and control the fan just fine.
All settings are as per the manual and the results/echo’s are as well.
25000 rate.
When I send a command manually, I can see the indicator LED on the board light up, and I’ve cycled through each one but I’ve still not had a single motor work. I’ve adjusted the voltage up to 0.55, although initial tests were at 0.425v.
[quote=“silverhawk”]25000 rate.[/quote]That is an incorrect baud rate
