hi i have put together my new k8061 and have a couple of probs…
on first start up, connecting to 12v only. ld13 to ld20 are lit ( as in the booklet )
and ld12 flashes. Is ld12 supposed to flash or be constantly lit ???
on second stage ( connect usb to Pc ) ld10 lit and i installed device drivers to Pc,
now ld9 ( usb ) and ld10 ( power ) are lit but rx/tx ld11 is dimly lit, should ld11 be lit ???
and finally i copied the 2 dll’s to win/sys32 folder run the demo and/or diag8061 it doesn’t connect " card not found ". but when i run demo through velleman cd the card is found. why don’t the demo or diag find the k8061???
[quote]but rx/tx ld11 is dimly lit [/quote]This is OK.
[quote]and finally i copied the 2 dll’s to win/sys32 folder run the demo and/or diag8061 it doesn’t connect " card not found ".[/quote]If you have a 64 bit operating system, copy the DLL files to subfolder SysWOW64
The package includes new driver and new DLL.
There are example projects written in many programming languages included.
There is also manual K8061_DLL_manual.pdf included describing all the DLL functions
You have to remove the previous driver and install the new driver (v1.0.0.6) from this download package.
Please read the Getting_Started.pdf and the README.TXT.
