Hi all, I have made this spool holder for the Vertex, as I am using Innofil 3D filament which comes with non-Velleman sized spools. It seems to work perfectly. Please feel free to try it out if you use Innofil 3D spools or leave a comment if you need other dimensions, then I’ll see what I an do (or simply remake it by using the Cubify Invent files).
[quote=“pmbdk”]Hi all, I have made this spool holder for the Vertex, as I am using Innofil 3D filament which comes with non-Velleman sized spools. It seems to work perfectly. Please feel free to try it out if you use Innofil 3D spools or leave a comment if you need other dimensions, then I’ll see what I an do (or simply remake it by using the Cubify Invent files).
http://www.thingiverse.com/thing:618269[/quote]
Just what I needed, thank you very much
