I’ve had a few issues in the past with the thermistor on the side of the old extruder and had to replace then several times, so when I learnt of the new extruder with the thermistor inside of it I decided to buy one!
Now I’ve just assembled it and tried to run a print at my usual settings - print temp 210degrees with pla and it’s smoking and the pla is running almost as a liquid out of the nozzle I tried turning the temp down and even at 170 it seems to be streaming out almost as a liquid.
I’ve also just noticed that around the thermistor the extruder has gone black?
Any help will be much obliged.
Thank you in advance!
Aleck
