Neutral PLA
Hello everyone.
Has anyone tried using Velleman 3mm PLA neutral filament? I need to make a part that is transparent as possible, and I dont know, what outcome Vellemans neutral PLA produces.
If anyone could add some pictures of prints with this filament, I would be greatfull.
I have used it.
You will not be able to see through it because it’s not transparent.
It would be like the cove of florescent lights like you find in an office.
Do you have any pictures or you can snap some?
Hy,
this is a French seller, but I think you can find same stuff in your country I guess.
I print with dutch filament, transparence is ok. I will print a flash diffuser soon
laboutiquedu3d.com/pla-3-mm/ … 50-gr.html
laboutiquedu3d.com/pla-dutch … -fluo.html
Good luck
What is that?
It is an example of a cylinder with a wall thickness of 1.5 mm using transparent filament. The device is a design of a low temperature stirling motor.
