Out of your kits, what can you recomend that can flash a single RED LED once about every 60 seconds?
It also needs to work on a +5V DC power supply.
Update 04/21/2014:
I just want to add that I purchased the MK111 Interval Timer and it works perfect for what I need. However when using +5 V it will not function. The LED just says lit. Would changing any of the values of the cap’s/resisitor make it work with 5 volts? My understanding is the 555 is functionable down to 5 volts.
