hi
I finished building my new printer .at first The Printer worked fine but once i wanted to clean the Nozzle.
While cleaning the Nozzle the Thermistor has a circuit to the ground and shows 643C° as temperature.
I tried to fixed this error and now the Thermistor shows 2C° temperature.
the printer won´t start. the Repetier shows an error:
Printer stopped due errors. Fix these errors and use M999 to restart.
I checked the wires and the power supply and they are fine.
When I give an order to move the printer engine .it write in written “idel” area; that it “waits for 5 command”. and yet does nothing , however when I press the HOME marks , the surface does moves to his place . Clicking on the fan also operates . But the attempt to turn the heater or controling the angine. fails
i tried to reconect the printer and i pressed the start b in the top right of the command boat. yet nothings happend.
How can i fix this problem ?
