Need help to find supply and stuff for a pre-assembled kit
Hi there,
I have some questions about http://www.velleman.eu/products/view/?id=4290222.
I can use the 3 pin input to transform to a jack cable which then can be used to plug into a mp3 device?
Do you guys have any ideas what is the best supply for this and which speakers to use?
I’m sorry for these kiddo questions and the plug in cables used to connect them are they included as seen on the datasheets?
Thanks for the info guys,
Kind regards
Leenen Dylan
The link you provided points to nothing.
Gould you give the part number of the item?
He’s talking about this
Velleman Modules MM210: CLASS D AUDIO AMPLIFIER - STEREO 2.8 W – Velleman – Wholesaler and developer of electronics (MM210)
Yes you can connect to a plug that can connect to an MP3 Player/SmartPhone.
The best power supply is batteries. I use 3x AA batteries to power the Amplifier.
Any power supply should do the trick, as long it can supply the power.
And yes the wires are included
