Hi
I am using the K8023 for a project but I’m new to electronics and need some help.
I’m done soldering and are on hook-up and testing.
I’ve connected the control VTX+ to the receiver VTX+ and the control VTX- to the recevier VTX-.
I’ve connected my 12 volt car battery to 12…15Vin on the Receiver card.
LD11 and LD12 are lit when power is on. I get about 10 volt on the VTX + and -.
When I connect com and any of the inputs 1 to 10 on the control, I get no corresponding response on the receiver. The only thing I notice is that the LD11 and LD12 flickers a bit. I have mesaured between the outputs (1 to 10) and GND on the receiver and get nothing.
I have’nt connected and power to +Vext. Should I do that? Or have I assemled the kit wrong somehow?
Most likely an assembly error.
No, there is only one spot where you should connect the battery.
Make sure to check it with a multimeter to make sure it delivers at least 12VDC.
Sorry to say, but numerous solder joints look suspicious and should be re-done.
Like I said I’m more of a mechanical guy. Sorry for maybe stupid questions.
In the suspicious joints you see, is it too much solder or do you see joints that is not soldered enough? Do you see places where you suspect that the solder create joints where it should not?
Have you got some advice on how I should proceed? I have gone through the cards with manifying glass and compared it to the schematic diagram.
I adjusted vr1, now it is the correct way. It still did not work.
And the trouble continues. While reading other topics here on the forum, I started measuring the voltage on the vr’s. While doing that I succeeded in burning the prefabricated connection between 12…15Vin and D2 on the card. I have no idea what else on the card that got destroyed.
This was a major set back for my project since I kind of depended on the functionality of the K8023. Maybe unassemblied kits just isn’t for me
