Need advice for temp reading
Hello everyone!
Well Im new here and I need advice with assembling device for monitoring and reading temperature in room through the network (ms based ), so what kit should I use and how can I connect it with a PC (if someone have a sample app). Please help cause I really need a device like that, option is the assemble a kit and a pc in the same case for that pourpose. Sorry on my english.
Thanks in advance!
Hi Klaus,
that is a really easy to fit experience.
Take that Velleman kit VM110 to buy from Conrad Elektronik in Germany.
You need a temperature-controller as well. You will find some good working at EBay.
The card is mounted to the USB-device, all driver come with it.
You can read the temp with DOS, VB, VB.Net
If you are German, I could help better… because of the language… :wink:
Greetings
Peter
