Hello, I’m Kenny from Belgium (industrial Engineer in chemistry) and i’m new to this forum. I ordered my first 3D-printer last week en started building this weekend.
The building and soldering is finished:
I’ve put some green protection cable over some of the connections for a nice finish:
But I encountered some problems with the printer, the first one is the gear on the X-axis motor which is not straight at all. This makes the belt wobble and vibrate allot when the bed is moving. So I hope to get a replacement part for this problem. The Y-axis gear also has a slight wobble but this one isn’t that bad.
The second problem was the connection rod between the z-axis motor and the threaded rod. This one was not straight at all and also gave allot of wobble. So we made a new one in aluminium. We also made a grip-pattern on the connection so it’s easier to turn by hand:
The first thing to do now is calibrating the printer and then the printing can begin!
First prints that are planned:
-Cover for motherboard
-Z-axis mount
-X-axis mount
-Ventilator nozzle (still thinking about which one)
Yesterday I also ordered a glass plate for the printbed and the standalone unit.
I will keep posting new improvements on my printer in this topic.
Update 22-02-2014
Here some other modifications:
Update 28-03-2014
Today I made a hole in the side of the mobo-cover to make the cable go all the way around instead of passing the other cables and all the problems from before are completely gone:
Today I also printed another upgrade for my printer:
Then I also printed the anti-vibration cups from thingiverse and i’m really stunned about the difference! The printer makes allot less vibration noise. Probably it will also improve the prints a tiny bit:
I have stuffed it with 3 layers rubber-foil and between each layer double sticky tape, so the cups are stuck to the printer and wont fall of when moving the printer around
I did not like the heat-bed cable being loose so I printed this:
Waste-bin for filament:
The printer is getting beter every day
Update 22-03-2014
Today I finished the build of a second Z-axis. Here are some photo’s:
Now I will have to test and see if the prints are improved
Update 5/04/2014
Bought myself the E3D hot-end upgrade for my printer and GT2 belts:
I also bought the nozzle pack with 0,25mm and 0,60mm nozzle
