improvement:
used, the stability of the aluminum frame.
you can move the horizontal frame in the middle of the vertical frame.
simply changing fillement.
easily switch from 3 mm to 1.75 fillement by changing the base block (1,75 mm block in development)
used the aluminum frame as an additional cooling.
