Multiple parts
I asked myself some questions but nowhere was the answer:
-Is it possible to print 2 distinct pieces in one run, i mean, can an assembly file, containing 2 elements be printed in one “job”?
-What about no-thickness items ? Some of my objects are designed only with empty volumes so their thickness is null.
you can load more than one part in repetier host but they are silecd with the same settings (same infill, speed temperature, …)
Thank you for this fast answer,
Can these parts, if they are stuck while printing, be separated safely afterwards ?
[quote=“InCo”]
Can these parts, if they are stuck while printing, be separated safely afterwards ?[/quote]
See here, Printed joint
including STL and FreeCad files. Its a assembled multipart, the two part have a clearance of about 0.5mm.
[quote=“InCo”]
-What about no-thickness items ? Some of my objects are designed only with empty volumes so their thickness is null.[/quote]
What does Slic3r do with this parts?
