Recently bought the K8200, took a long time very carefully building it and double checking everything.
Very unhappy with this, things wrong are as follows:-
Z axis lead screw not straight
Z axis motor mount incorrect fit
Z axis micro switch does not line up with stop bar
X axis motor noisy
Print bed warpped
Controller stuck in test mode???
No comunication with software even though shows as connected!
What can be done please?
The control board is the first issue that we need to address and any software issue. The lead screw and motor connector can be seen bent when moving.
The led on the board at LD2 is permanently on and the fan always on.
The led at D4 (heater 2) is flashing randomly
No led seen at the usb port when power is on.
