Do you guys have any plan of updating the Firmware to a dual or quad extruder? (Something like E3D Extruders)
Also, do you have any plans of updating th VM8201 stand alone to wifi or bluetooth?
Thanks in advance
Thanks in advance
Sorry, at this time, we do not have such plans, we focus on new designs
Is it possible to use a Vertex control board in the K8200 so that dual extruders can be used???
Is the vertex control board the same size??
Vertex board is larger.
Also: end-stops are optical instead of switches.
Firmware will need tweaking too, since most likely different ports are used.
