Move Z-axis down after a successful
Hi, with my K8400, I would like to move the bed down to Z=150 or 160mm as it will be easier to remove my object. Do you know where I should have a look ?
I found nothing in Repetier. I think I should study the firmware code but no idea in which file…
Under Slicer -> Configuration -> G-Code Tab -> End GCode
You can add an additional line to run on completion, something like:
G1 X0 Y0 Z150
That will move the bed down 150mm after job completion.
I have thought about doing this.
However what would happen if the print is say 170?
Would it move the bed back to 150?
Thanks birket, it works perfectly.
I discovered I can also use something like this : G1 F150 Z150 to control the speed of the Z-axis.
Last thing I’m trying to do : extruding some filament after while going down after a successful print. I have to check in the G-code where the extruder is stopped :wink:
[quote=“Wrong Way”]I have thought about doing this.
Would it move the bed back to 150?[/quote]
Yes, it would move the bed back up. This would only be a problem for very large footprint objects, as the head will move out of the way to X0, Y0.
ZMax is 190 - which is guaranteed to always move the bed down.
Thought about this also…
Is there a G-Code command that will say: “move to Zmax” ? - like for the Vertex printer - Move to Z190 @ as absolute ?
To do this, set the following code in the End G-code :
G90 ; Absolute positioning G1 X0 Y0 Z190
The head will move to the front left corner and the bed to 190.
