Mouse troubles
Now that I have the printer up and running nicely, I have noticed one odd thing with the computer mouse.
I’m running XP Pro SP3, Repetier 0.95 and the Marlin 1. Wired in keyboard and mouse, 3.11 speed intel computer.
I set everything up and print my first project.
If I try and print another one after, I get the problem. Most of the time I will close the program and it comes up with a repetier error. I get the dialogue of ‘send report’ or ‘close’ like usual. “Repetier Host has reported an error and needs to close. Sorry for the inconvenience” is what it reports.
In both instances, the mouse starts behaving randomly. It’s extremely slow and as you move it, it randomly right clicks for no reason and jumps around the screen. If you try to move the mouse to the right, it right clicks randomly. If you left click, it zooms in instead and refuses to zoom out, and right click does nothing. The only way to get the mouse to do what you want is to move it excruciatingly slowly, and even then it sometimes jumps or clicks. If we can get to restart the computer, it still does it. If we turn off the computer completely, then press the button and start the computer again, the mouse returns to normal operations.
Checked the computer for viruses and malware, but is clean.
It only does it when Repetier is opened then either 2nd print or closed. All other programs are ok.
UPDATE:
I can open and close repetier without doing anything - no error
Open and import STL file then close - no error
Open and import STL, slice with Slic3r close - application error for repetier.
Open and import STL, Slice with Slic3r, start printing. Seems OK until you do another print or close program then the mouse start behaving as above.
Slic3r or repetier?
This is from the Repetier support page:
repetier.com/documentation/r … iguration/
[quote]
Repetier-Host Documentation
Installation
Prerequisites
Before you start with the installation, you should check if your computer meets the requirements. Currently available computers should have no problems at all. If you have an old computer running Windows XP you may have difficulties.[/quote]To be honest, Windows XP is dead and buried :slight_smile:
