** Mounting tips from me of every critical step <- MUST SEE!
I had my hard time to mount this printer. But after the end I did it. I also documented nearly each step which I did not as stated in the official documentation.
Revision: AUG.2013. Subject may change. It’s maybe useful for someone out there. Sorry, only in German right now.
Download PDF: mustun.ch/michael/works/vell … erfahrung/
Had he same problem, for me it was easier to loosen the motor and the Z-guider, this way you can move the guiderod up and down and thus make the adjustments needed
Hope it helps,
Take care
