matt78
October 7, 2013, 4:44pm
1
I’m having problems configuring the printer.
None of my motors work, or the fan. I’ve checked the connections and set the power at 0.55, but still nothing?
I’ve tried the heater bed and the extruder and they work.
When trying to move the arms manually is there a “send” command or should they move when you press the arrows?
Please help!
VEL327
October 9, 2013, 2:15pm
2
Are you seeing a good USB connection to the mainboard as explained in the manual?
PeterH
October 12, 2013, 10:53am
3
today I got the same Problem.
I printed the last few weeks without Problems.
And today the X-, Y,- and Z-Motor don’t work any more. The fan, Extruder and bad work.
I didn’t Change anything (Software, …). I tried reset, reboot -> same Problem.
Peter
VEL327
October 14, 2013, 6:57am
4
To be clear, are you able to establish a good connection between the printer and the PCB (do you see the extra information in the log window when you press connect).
PeterH
October 15, 2013, 5:31pm
5
I tried today again.
The USB-Connection (and all the other Connections for the Motors) still work, because Fan, Bad and Extruder work.
The X-, Y,- and Z-Motor not.
Please help
VEL327
October 16, 2013, 6:52am
6
Do you see the lights at each driver light up when you expect that the motors should turn?
PeterH
October 16, 2013, 4:22pm
7
If I try to work the Motors manually. For each click the red/gree light flashes … but nothing happened …
VEL327
October 17, 2013, 6:33am
8
I mean if you give a command via the PC do you see the LED’s light up.
PeterH
October 17, 2013, 4:35pm
9
Yes. If I give a command via PC the LED near the USB-Cable flashes …
VEL327
October 18, 2013, 6:37am
and do you then see the leds near the drivers light up?
PeterH
October 19, 2013, 7:08am
11
I’m not sure where there are. If I give commands from Computer I have:
LED for Connection works
LED for Reset works
LED for fan works
LED for Printer bed works
LED for Extruder works
For the X-, Y- and Z-Motors only the Connection LED (red/green flashes). Nothing more …
VEL327
October 21, 2013, 6:58am
12
There are 4 LEDs besides each driver, they are small but when they light up you should see them clearly. If they do not light up it is normal that the motors are not turning as they indicate that the controller sends a signal to a driver/motor.
Could you check if one of your temperatures has an abnormal value? (0.00° or a really high temperature)
As the printer will go into safe mode when this is the case and you will never get a motor to turn.
PeterH
October 21, 2013, 4:39pm
13
The LED don’t light.
And the temperature Shows me 18,5° C at the Moment. Both sensors (Extruder and bed).
And if I give a command via Computer the tempretures rises up.
VEL327
October 23, 2013, 7:33am
14
Could you post a copy of your log (with Commands - Infos - Warnings - Errors - Ack active)
when you are trying to move the motors?
PeterH
October 25, 2013, 3:50pm
15
this is the log, if i try to move the bed via PC:
17:48:55.197 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup FIRMWARE_URL:http://www.K8200.eu - velleman.eu PROTOCOL_VERSION:1.0 MACHINE_TYPE:K8200 - 3D PRINTER EXTRUDER_COUNT:1
17:48:55.197 : N6 M220 S100 *71
17:48:55.197 : echo:Active Extruder: 0
17:48:55.197 : N7 M221 S100 *71
17:48:55.197 : N8 M111 S6 *79
17:48:55.213 : N9 M80 *50
17:48:55.228 : N10 M105 *54
17:48:58.286 : N11 M105 *55
17:49:01.343 : N12 M105 *52
17:49:04.401 : N13 M105 *53
17:49:05.259 : N14 G91 *4
17:49:05.259 : N15 G1 Z-1 F150 *8
17:49:05.259 : N16 G90 *7
17:49:07.459 : N17 M105 *49
17:49:08.348 : N18 G91 *8
17:49:08.348 : N19 G1 Z1 F150 *41
17:49:08.348 : N20 G90 *2
17:49:10.516 : N21 M105 *52
17:49:10.953 : N22 G91 *1
17:49:10.953 : N23 G1 Y10 F1500 *35
17:49:10.953 : N24 G90 *6
17:49:13.574 : N25 M105 *48
17:49:15.586 : N26 G91 *5
17:49:15.586 : N27 G1 X10 F1500 *38
17:49:15.586 : N28 G90 *10
17:49:16.631 : N29 M105 *60
17:49:19.689 : N30 M105 *52
VEL327
October 28, 2013, 8:48am
16
Hi is it possible you did not have all the lights on active: Commands - Infos - Warnings - Errors - Ack should be active.
Because your log seems half complete.
PeterH
October 28, 2013, 6:19pm
17
Ok here are alle Infos:
19:15:00.847 : OpenGL version:2.0.0 - Build 8.14.10.1930
19:15:00.847 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_separate_specular_color GL_ARB_multitexture GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_pixel_buffer_object GL_WIN_swap_hint GL_EXT_framebuffer_object
19:15:00.847 : OpenGL renderer:Intel 965/963 Graphics Media Accelerator
19:15:00.847 : Using fast VBOs for rendering is possible
19:15:09.895 : N1 M110 *2
19:15:09.895 : N2 M115 *4
19:15:09.895 : N3 T0 *25
19:15:09.895 : N4 M105 *3
19:15:09.957 : N5 M111 S6 *66
19:15:09.957 : N6 M80 *61
19:15:09.957 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup FIRMWARE_URL:http://www.K8200.eu - velleman.eu PROTOCOL_VERSION:1.0 MACHINE_TYPE:K8200 - 3D PRINTER EXTRUDER_COUNT:1
19:15:09.957 : echo:Active Extruder: 0
19:15:09.957 : N7 M80 *60
19:15:10.113 : N8 M105 *15
19:15:10.113 : N9 M220 S100 *72
19:15:10.113 : N10 M221 S100 *113
19:15:10.113 : N11 M111 S6 *119
19:15:13.015 : N12 M105 *52
19:15:16.073 : N13 M105 *53
19:15:19.130 : N14 M105 *50
19:15:22.188 : N15 M105 *51
19:15:22.203 : ok T:19.2 /0.0 B:20.0 /0.0 @:0
19:15:25.245 : N16 M105 *48
19:15:25.261 : ok T:19.2 /0.0 B:20.0 /0.0 @:0
19:15:28.256 : N17 M105 *49
19:15:28.256 : ok T:19.2 /0.0 B:20.0 /0.0 @:0
19:15:30.534 : N18 M106 S128 *117
19:15:30.549 : ok
19:15:31.314 : N19 M105 *63
19:15:31.329 : ok T:19.2 /0.0 B:19.9 /0.0 @:0
19:15:31.719 : N20 M107 *55
19:15:31.735 : ok
19:15:33.872 : ok
19:15:33.872 : N21 G91 *2
19:15:33.888 : N22 G1 Z1 F150 *33
19:15:33.888 : N23 G90 *1
19:15:33.888 : ok
19:15:33.888 : echo: cold extrusion prevented
19:15:33.888 : ok
19:15:34.340 : N24 M105 *49
19:15:34.356 : ok T:19.2 /0.0 B:20.0 /0.0 @:0
19:15:35.448 : N25 G91 *6
19:15:35.448 : N26 G1 Z10 F150 *21
19:15:35.448 : N27 G90 *5
19:15:35.463 : ok
19:15:35.463 : ok
19:15:35.463 : ok
19:15:37.429 : N28 M105 *61
19:15:37.445 : ok T:19.2 /0.0 B:20.0 /0.0 @:0
19:15:38.162 : N29 G91 *10
19:15:38.162 : ok
19:15:38.162 : N30 G1 X10 F1500 *32
19:15:38.162 : N31 G90 *2
19:15:38.178 : ok
19:15:38.178 : ok
19:15:39.878 : N32 G91 *0
19:15:39.878 : N33 G1 X10 F1500 *35
19:15:39.878 : N34 G90 *7
19:15:39.894 : ok
19:15:39.894 : ok
19:15:39.894 : ok
19:15:40.487 : N35 M105 *49
19:15:40.502 : ok T:19.2 /0.0 B:20.0 /0.0 @:0
19:15:43.544 : N36 M105 *50
19:15:43.560 : ok T:19.2 /0.0 B:20.0 /0.0 @:0
19:15:44.496 : N37 G91 *5
19:15:44.496 : ok
19:15:44.496 : N38 G1 Y10 F1500 *41
19:15:44.496 : N39 G90 *10
19:15:44.512 : ok
19:15:44.512 : ok
19:15:46.649 : N40 M105 *51
19:15:46.649 : ok T:19.2 /0.0 B:20.0 /0.0 @:0
19:15:49.706 : N41 M105 *50
19:15:49.706 : ok T:19.2 /0.0 B:19.9 /0.0 @:0
19:15:52.764 : N42 M105 *49
19:15:52.764 : ok T:19.2 /0.0 B:20.0 /0.0 @:0
19:15:55.229 : N43 M104 S190 *122
19:15:55.244 : ok
19:15:55.822 : N44 M105 *55
19:15:55.822 : ok T:19.2 /190.0 B:19.9 /0.0 @:127
19:15:57.257 : N45 M104 S0 *116
19:15:57.257 : ok
19:15:58.879 : N46 M105 *53
19:15:58.879 : ok T:19.9 /0.0 B:20.0 /0.0 @:0
19:16:01.937 : N47 M105 *52
19:16:01.952 : ok T:21.0 /0.0 B:19.9 /0.0 @:0
19:16:02.452 : N48 G91 *13
19:16:02.452 : N49 G1 Y-10 F1500 *2
19:16:02.452 : N50 G90 *5
19:16:02.452 : ok
19:16:02.452 : ok
19:16:02.452 : ok
19:16:05.010 : N51 M105 *51
19:16:05.026 : ok T:22.0 /0.0 B:20.0 /0.0 @:0
19:16:08.068 : N52 M105 *48
19:16:08.083 : ok T:22.5 /0.0 B:20.0 /0.0 @:0
VEL327
October 29, 2013, 7:40am
18
Your Gcode looks alright. There is good comunication.
Hmm it’s a weird situation. Could you please send your motherboard together with a description of the problem to:
Velleman Repair Service
Legen Heirweg 33
9890 Gavere
Belgium
We will check the board and send you a new one asap free of charge.
Sincerely
matt78
November 3, 2013, 3:11pm
19
Now I’ve got the time I’ve been trying to get the printer going following the advice you’ve given peterh (hope yours is working ok)
This is what happens on my printer:
When I plug in the USB the red and green lights come on and stay on.
When I plug in the power the USB lights go out. A green light flashes twice. The green light on the power supply box stays on.
When I try to move the ‘Z’ arm nothing happens.
This is a copy of the gcode:
14:58:49.144 : OpenGL version:2.1.2
14:58:49.146 : OpenGL extensions:GL_ARB_color_buffer_float GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_ES2_compatibility GL_ARB_explicit_attrib_location GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_robustness GL_ARB_sampler_objects GL_ARB_separate_shader_objects GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_storage GL_ARB_texture_swizzle GL_ARB_timer_query GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_gpu_program_parameters GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_alpha_test GL_NV_blend_minmax GL_NV_blend_square GL_NV_complex_primitives GL_NV_copy_depth_to_color GL_NV_depth_clamp GL_NV_ES1_1_compatibility GL_NV_fbo_color_attachments GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragdepth GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_lod_clamp GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_OES_compressed_paletted_texture GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_point_size_array GL_OES_point_sprite GL_OES_rgb8_rgba8 GL_OES_read_format GL_OES_standard_derivatives GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_vertex_half_float GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
14:58:49.146 : OpenGL renderer:GeForce 7100 / nForce 630i/integrated/SSE2
14:58:49.146 : Using fast VBOs for rendering is possible
14:59:29.022 : start
14:59:29.040 : ok
14:59:29.040 : N1 T0 *27
14:59:29.041 : N2 M111 S6 *69
14:59:29.041 : ok
14:59:29.042 : N3 M80 *56
14:59:29.052 : N4 M220 S100 *69
14:59:29.052 : N5 M221 S100 *69
14:59:29.095 : FIRMWARE_NAME:RepetierVirtualPrinter FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 REPETIER_PROTOCOL:1
14:59:29.096 : ok
14:59:29.096 : N6 M111 S6 *65
14:59:29.099 : ok
14:59:29.099 : ok
14:59:29.099 : ok
14:59:29.099 : ok
14:59:29.099 : ok
14:59:29.099 : ok
14:59:29.099 : ok
14:59:29.100 : N7 M105 *0
14:59:29.103 : ok
14:59:32.152 : N8 M105 *15
14:59:32.154 : ok
14:59:35.214 : N9 M105 *14
14:59:35.216 : ok
14:59:36.570 : N10 G91 *0
14:59:36.572 : ok
14:59:36.572 : ok
14:59:36.577 : N11 G1 Z10 F150 *17
14:59:36.577 : N12 G90 *3
14:59:36.578 : ok
14:59:38.271 : N13 M105 *53
14:59:38.272 : ok
14:59:41.325 : N14 M105 *50
14:59:41.326 : ok
14:59:44.382 : N15 M105 *51
14:59:44.384 : ok
14:59:47.443 : N16 M105 *48
14:59:47.444 : ok
14:59:50.365 : N17 G91 *7
14:59:50.365 : N18 G1 Z-10 F150 *53
14:59:50.365 : N19 G90 *8
14:59:50.366 : ok
14:59:50.366 : ok
14:59:50.366 : ok
14:59:50.497 : N20 M105 *53
14:59:50.500 : ok
Any ideas?
BerndJM
November 3, 2013, 11:59pm
20
this is the “critical” line:
it should be:
FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup FIRMWARE_URL:http://www.K8200.eu - http://www.velleman.eu PROTOCOL_VERSION:1.0 MACHINE_TYPE:K8200 - 3D PRINTER EXTRUDER_COUNT:1
compare it with the posted code from PeterH!
This means you haven’t set the correct printer in your settings, so your computer talks with a virtual printer and not with the real existing hardware.
Hope this helps
Regards Bernd
