Motor issue - No movements on all axis
What is wrong with my K8200 printer?
None of the motors rotates anymore.
Extruder and heatbed works fine on manual.
Have you done any firmware updates to it?
If so use the Arduino software 1.0.6 or lower.
Did you upgrade your operating system?
In the printer settings
Check that the comport is correct.
Reset on Connect is set to Disabled.
Hi Wrong Way,
No firmware update was made.
I use the Repetier software.
The printer stoped while it was printing.
The pc screen was turned into a bleu screen. Reset and restart the pc…again a bleu screen.
Two of the four memmory banks was demaged.
After repairing the pc is working perfect again.
Com port is oke. The printer is connecting with the pc.
Files can be loaded and sliced.
Extruder and printbed heating is oke.
Last but at least…the motors are not working at all.
Did you check the printer settings?
You might try reloading the firmware.
