I have K 8055 USB board. I have managed to display the output of the sensor on the PC but i don’t know how to use this voltage to make the actuation of a motor.Can you please guide me in this regard that how can i make the actuation of the motor (changes in software program).
I am new to all this electronic stuff so can you please give me some new basic VC++ codes so that i can play with the borad by making changes in the program.
Moreover i want to display the data of rotational speed sensor. Data sheet of which can be founf from the following link.
We try to help you if you encounter some problems using the K8055 card in your application.
With that information you gave it is not possible to give any suggestions how to proceed.
What kind of motor are you trying to control? (Type, voltage, current etc…?).
Have you written any code for the K8055 yet?
About the C++ programming please download the files listed below for some info. Sorry, no other code available at the moment.
Maybe you’ll find some from the Web using Google…
