More then 1 K8055 will not work on 1 compter
hi everyone
im only new to all this but i have hit a small problem with my K8055 cards
i have them all setup in my car and if i use one at a time they work well but if i try and use all 3 the IO’s start to do funny things and the AN inputs of all the cards display the value of the first card.
i have the cards setup as 0-2-3 but i have changed it and i has made no difference
im not big on computers and programming so i am using ProfiLab Expert 4 to make a program.
i also downloaded the latest DLL and that didn’t help but im not 100% sure im using it or not
ANY HELP WOULD BE REALY GOOD
THANKS KEVIN
After extracting the latest downloaded software package you get the following folders:
\Demo
\DLL_v4.0.0.0
\Examples
You may test if the cards work OK by running the program K8055_Demo.exe in the folder Demo.
The radio buttons “Device 0” etc. should be activated if you click the button “Search Devices”.
Then you can select the active card by clicking the radio button associated with the card address.
[quote]i have them all setup in my car and if i use one at a time they work well but if i try and use all 3 the IO’s start to do funny things and the AN inputs of all the cards display the value of the first card.[/quote] Is there this problem with the analog input values with the demo program too?
Hi
thanks for your fast reply
i just went out and checked them using the K8055 Demo and all 3 cards work 100%
but once agian when i create a simple program with ProfiLab Expert 4 (abacom-online.de/default.html) to control all 3 at the same time it does not work.
its only a simple program with switchs on the out puts and lights and meters on the inputs.
i know most people probably dont use this type of program but for me it works as i dont have any programming skills.
so any help would be good
thanks agian for your speedy reply
Are you using the SetCurrentDevice function to switch the control between the cards?
Please see also this thread: viewtopic.php?f=15&t=3036
