Building the printer was not to difficult. Build by numbers.
Made a couple mod’s to the desing.
1st. Extruder wires I used a connector.
This makes it easy when you need to disconnect the extruder (fixing a blocked extruder)
Funny,
did initialy the same modification on the heading bed, because the mentioned connection method in the manual looks for me a bit suspect
Also made a little terminal-box (hadn’t convinient connectors on the hand) for connecting the whole extruder stuff.
As soon as I have to remove one of those components, i will make the same mods. I then try to find a solution without limitting the Y Axis (eg a 90° Wago connector).
