MK195 operating instructions
I have checked all downloadable documents for this kit, but none of them contain operating instructions (the user manual only gives Building instruction).
e.g. How do you update/replace a recording. How do you delete ALL recordings
Can you please publish operating instructions
There is an erase button on it.
You may have to press it several times.
Thanks for the reply but this doesn’t really help. And that was only an example of one issue.
I had already worked out by trial and error how to use the erase button. i.e. it only erases the last recording on each button press. This means that to erase say recording 3 of 10 I have to erase recordings 3 to 10. This is not desirable as I only want to erase recording 3 and replace it with a different recording. Is it possible to do this?
A full set of operating instructions should explain this. Is there such a thing. Or do I have to figure out all the operational possibilities / limitations myself, by trial and error?
Has nobody else asked for operating instructions ?
regards
John
