Hi!
I bought my mk193 yesterday and finished the soldering today.
Super excited i connected the battery and the lights starts flashing except all the lights on plane 1.
So after some research i found out that all the leds on plane 1 is wrong settled. so plus is to minus.
So after about one hour of fixing that i again connected the battery. Now they was flashing to but only a little bit.
But i didn’t mind then so i tried to connect to the computer. I installed the drivers and the program. Everything worked fine and i could even send my animations to the cube. Suddenly when i tried to send an animation to the cube the progress bar just stayed at 0%. So after 5 min i tried to stop the sending but the program refused. So i forced the program to shut down with the task manager. Then i tried disconnect the cube from the computer and connected it to the battery. Nothing happened… So i pressed the switch on the cube, still no reaction. Then i tried holding the switch in, suddenly the leds started flashing. As soon as i release the switch the flashing goes away.
note. One of the resistance is badly soldered on the PCB backside. I have soldered it better to the PCB;s front side.
My problems:
- Plane 1 leds are barely flashing.
- The leds only flash.
Images of the soldering:
http://gyazo.com/cc53e51fd5bcfa06dd6942454c2b738c
http://gyazo.com/79c1a39b394ea342d39a124a6ac32de6
Video of the flashing leds:
https://www.youtube.com/watch?v=lZM-9Dl6iCE
