Mk180
I just bought the MK180 kit. Can someone tell me how I can use this kit for 4 blocks of there High Power Leds (4x3 1W 3,7V 350mAh each)? Do I need to make a modification? and if so, please tell me what I need to change.
Do I also need a Power Driver for this leds?
*** 3 x 1W channel A
*** 3 x 1W channel B
Thanks for helping me out.
Regards,
Frank
You should change the series resistor of the LED’s according to the current of the LED’s, the total voltage of the LED’s (series? parallel?) and the voltage used to power them.
Thanks for your answer.
I think I have to change the R2 … R7 to another value. Is that right?
What is the output voltage per channel. I can’t find this in the manual.
Thanks for helping me.
Regards,
Frank
No, only R4…R7, depending on how you configure your LEDs.
Voltage “output” is almost the same as the power supply.
Please try to understand schematics and electronics before you start changing and adapting kits because you can get into trouble (fire, burned skin, …) when making errors/faults.
