I would like to power two high power CREE LED from your board. They shall be supplied with 3,3V and 3A each. To limit the current at 12V output I need a very large resistor (capable to dissipate 26W) which gets very hot and is very heavy due to cooling.
Since the whole thing is for a model plane weight has to be limited.
Question: can I power the board with 5V bypassing the step-down like that:
When I have only 5V output I would only dissipate 5W with a much lighter resistor.
I also should bypass the diode D1 to avoid the voltage to drop I guess from another thread…
Right?
You can power it from 5VDC, however, keep in mind that the unit is no longer protected against polarity reversal and don’t forget to put a resistor in series with the leds.
So, I do not have to bypass the step down just power the whole thing with 5VDC and calculate the resistors for 5VDC?
I come to result of 0,57 and 5W to be dissipated:
Hello Guys. Yesterday i bought the mk180 Module. This Module ist ready for 9-12v DC. But i only have an 5V Output from another Module. Couldt anybody tell me how i can modifi the mk180 to get it working with 5V?
