Mk179
The presentation document shows a hand made coil, the kit came with a print circuit coil. What are the rules to make a different coil?
I did not find the schematic of the kit in the blister. Where can I find it?
Coil specs can be found on the base PCB.
[quote=“gesi”]The presentation document shows a hand made coil, the kit came with a print circuit coil. What are the rules to make a different coil?
I did not find the schematic of the kit in the blister. Where can I find it?[/quote]
I looked carefully to the base PCB for the specs of the coil, but found only the text “COIL”.
How can I make a coil of 3,5 cm diameter and another of 10 cm diameter?
Apparantly, on version 2 of the PCB the info is omitted.
Anyway, the coil can be made with 40 turns of 0.4mm wire.
