Hi
I recently purchased one of your MK179 proximity card reader kits, firstly found that two incorrect valued resistors came with the kit even though i found a post relating to this dated sep 09 your kit still seems to be shipping with these incorect value resistors, but even after building the kit with the correct resistors i have found a few problems that i would like some conformation on.
1: The software programme does not allow you to delete a single card or all cards as stated in your instructions, after trying to delete a card or all cards they still work and activate the relay (not very good security) could some please expain why this is not functioning as per your instructions.
2:Why is there no connection on the main pcb to connect an exit button to the system ??? how is someone supposed to exit the protected area if the locking device is purely electric with no mechanical lock handle available for use to exit the protected area.
a quick response would be apprieciated!!! many thanks
