MK179: 2 doors/1 key
same tag for 2 MK179 (following)
Hi
you think “it is possible to learn the same tag to 2 units”
:question: but is it only on “low security mode” or it is possible with high security 64 bit code
:exclamation: how to get the same code for my 2 units without it being possible for any user of a MK179
thanks
A unit learns a tag (puts it in its memory) in learning mode. When a unit reads a tag and that tag is in its memory, it will give an OK (open a lock or whatsoever).
So you can learn your tag to 100’s of units, even in 64-bit mode.
Another user with another tag can’t open the door because the tag will not be in the memory of your MK179 (unless you learned it).
When the other person can put the MK179 in learning mode, it is possible he makes your MK179 work with his tag.
