Hello, I build the kit mk 171 but it doesn’t work properly. When I put the power on, the two red leds burn and there is some undeterminable sound. I can’t record anything. There is no description how to work with the kit. Who can help me ?
All necessary instructions can be found on the blister card and on the the PCB.
Most likely there are one or more assembly problems.
