MK163- Using at instrument (guitar pickup) level
Hello!
I’m a bit uncertain of my level of competence/understanding…
Does anyone have any insight into how the MK163 kit will behave with an input level of around 0.077Vrms (-20dBu). So the max is 2Vrms, but can I assume it treats a signal lower than line-level the same? With the volume on the kit at full, it will just output at that same input level will it not?
Also, any idea what sort of impedance this has? The unit I’d like to use it with has a recommended load impedance of 10 k ohms or greater.
Hope these questions make sense!
Many thanks in advance,
Ropati
This is a line level device. The level of a guitar pickup coil is way too low.
You need to put this device between the pre-amp and the power amp.
