I use my MK161 in combination with a Logitech programmable remote to control dimmable lights in my home.
Everything works fine, but to switch the light on/off the relay needs to send a shorter puls.
Is it possible to change de puls duration?
Sorry, the pulse length is determined in the firmware and cannot be changed.
In order to achieve a shorter pulse, you could modify one relay output.
Keep the other relay original,for dimming, and connect both outputs in parallel to your dimmer input.
The output that needs to generate a shorter pulse can be modified as shown. Experimenting with cap & resistor value will reveal correct values.
Please allow 1h for server refresh.
