MK160 info, please
Hi!
I have a personal project and your mk160 could be just what I need. However, my project requires hardware which is operating below 0C degrees.
As I’ve learned from this forum is that the PIC 12C508 may have problems operating below 0C. Are there other parts which may have problems below 0C, too?
I’ve also learned that, if the custumer source an equivalent industrial part, you may program it. Please confirm if this is still valid and if the one below is the correct industrial equivalent for your PIC 12C508:
MICROCHIP - PIC12C508-04I/SM - 8BIT CMOS MCU, SMD, 12C508, SOIC8
Fabrikant: MICROCHIP
Ordercode: 1196846
Fabrikantnummer: PIC12C508-04I/SM RoHS Compliance : Yes
Omschrijving 8BIT CMOS MCU, SMD, 12C508, SOIC8
Controller Family/Series:PIC12
Core Size:8bit
No. of I/O’s:6
Program Memory Size:768 Byte
RAM Memory Size:25Byte
CPU Speed:4MHz
Oscillator Type:External, Internal
No. of Timers:1
Digital IC Case Style:SOIC
Supply Voltage Range:2.5V to 5.5V
Operating Temperature Range:-40°C to +85°C
No. of Pins:8
SVHC:No SVHC (20-Jun-2011)
Clock Frequency:4MHz
IC Generic Number:12C508
IC Temperature Range:Industrial
Logic Function Number:12C508
Memory Configuration:512 x 12
Memory Size:512 B
Memory Type:OTP
Microprocessor/Controller Features:INTERNAL OSCILLATOR,ISP, IND TEMP
No. of Bits:8
No. of External Interrupts:0
No. of I/O’s:6
OTP Memory Size:6KB
Operating Temperature Max:85°C
Operating Temperature Min:-40°C
Package / Case:SOIC
Program Memory Size:768Byte
Supply Voltage Max:5.5V
Supply Voltage Min:2.5V
Termination Type:SMD
If yes, please let me know the address and contact person to whom I should send it!
As I’ve said, this is a personal project, but if it proves reliable, than I would like to market it at a larger scale. In this respect, is the programing of the industrial equivalent part still valid and there is any posibility to cooperate directlly, w/o intermediaries?
Thank you for your support,
Alex Bianchi
This was a one time offer, and we can offer it again, for one piece.
Should you require more items, then we will have to charge for shipping and handling.
You can send your PIC to:
Velleman Projects Tech. Dept.
Attn: Pascal De Petter
Legen Heirweg 33
9890 Gavere
Belgium
Make sure to include a copy of this conversation.
Thank you!
My PIC supplier (an on-line shop) can deliver it directly to your premises, in which case I cannnot provide a copy of this conversation to Mr. De Petter.
Could you please provide Mr. De Petter contacts at my email address: alex@adproject.ro?
