Attempted to build this one up following success with a smaller project but having done so I find that the clock does not function correctly.
The display lights up but segments appear to be missing, the display does not form correct numbers, flashes on\off at random and it does not set.
All seemed to go ok during construction, I was careful to get the correct polarity and the solder joints seem good etc, I can’t think where I might have made a mistake… are there any particular areas that I need to check?
I have a wire bridge left over but I can’t find where it is supposed to go (if anywhere) checked twice and found no mention of it in the instructions?
Total newbie…don’t go getting all technical on me!!!
Cheers !!
