MK147 12v Prewired LED
Could someone help me adapt the MK147 for a 12v (automotive) application. So here is basically what i have; my power source will be a keyed on 12v power source, one of the LED’s will be “raw” not prewired that will go to a control panel (where i will relocate the pot and on off switch) and the other LED will be prewired for 12v. I know the one “raw” led will need a resistor and the second will not (since its already prewired with one). So, i need to know how to make this circuit work. Do i put a jumper in place of R4 and R7 and wire inline a resistor for the “raw” led? Does it matter which socket i use to wire the “raw” led and prewired led? Also if i’m forgetting anything else, please let me know.
TIA for the help!
-Alex
Sorry, it is not clear to us what you are trying to do, please elaborate.
Anyway, unit works fine on 12VDC.
