Electronic decision maker switch and lights work…but when lights stop flashing, only “yes” or green LED stays lit.
It never stops on “no” or red light???
My first guess would be that you may have T1 and T2 swapped or the red LED is in backwards
OK Thanks…I will check that…
T1 T2 both OK problem was a piece of a clipped resistor lead was stuck on the solder side of the board
by the flux and was shorting out the IC circuit. As soon as I removed the rogue lead…unit started working correctly!
Thanks for your help.
Glad to hear it’s working.
Enjoy!
