Mk133
Hi there,
I’ve been tasked with making a “game show” light indicator. I found the MK 133 and I think it will do what I need. I only need 2 lights, and the reset. So, my plan is to run wires from each button I plan to use, to separate DC/AC SSR switches then to 120volt fixtures with larger LED bulbs. The switches require at least 3volts to activate the. Will the button LED on the board produce enough voltage to activate the switches?
