My quiztable MK133 doesn’t work for any of the leds. I believe I followed the instructions quite neatly, so I am not sure where I made an error. If someone could take a look that would be amazing.
Thanks for looking at the pictures. The transistors are all in the right places, but you’re right about the solder pads. They have lifted off a bit, but the connection has not been broken. Do you happen to know what’s the best way to try to fix this? Or is this not possible?
It worked! I did exactly as you said with the trace near the three arrows and it works completely without problems right now. Thanks for taking the time to take a look
