Mk131
hi I have mk131 kit…when I turn it on I get two red leds and 1 green led light…it never changes…I am a experience builder…i check everything over and over all leds are in correct…any one have any ideas? thank you all that respond
Pat
SOLVED THE ISSUE …but I am lost on the light sequence…the middle leds make sense…green to yellow to red…then red go to green…make sense…but I have no idea whet the outside lights are doing?..can someone explain that sequence??
Happy to read that you were able to solve the problem.
What sequence do you see on the outside leds? This will allow us to determine if the behaviour is normal or not.
