Sorry to say, but most likely an assembly problem is at the cause of troubles.
Hereby the diagram and PCB layout, to allow troubleshooting. http://www.velleman.eu/images/tmp/mk124.jpg http://www.velleman.eu/images/tmp/http://www.velleman.eu/images/tmp/mk124.jpg
Should you be unable to solve the problem, then you can return the kit for inspection/repair.
