I’ve done a fair amount of soldering before, but never to such tight tolerances as the gaps between the holes for the MK124 kit.
After soldering the first few jumpers in, I realized that I may have unintentionally made the solder joints too large, so that the solder unintentionally contacts the copper pads for adjoining holes.
Problem is, I don’t have an image of the PMK124-1 circuit board before any soldering to know if I’ve messed up or not. I do see shorting, for example, between the J2 holes and the holes directly “below” (toward the bottom of the board).
Can you tell if I messed up? If so, should I attempt to de-solder and try again but using less solder? I looked but couldn’t find an image of the PMK124-1 board non-component side; do any exist?
Any advice appreciated.
Thanks,
Marty
