The bottom row is all lit up; with the left most LED being 2x brighter than all other LED’s on the board.
All the links I have found on this forum for the schematic are bad 404 not found.
Thanks for the link.
Ay ideal why the bottom row is let up?
Most likely an assembly error.
[quote=“VEL417”]Most likely an assembly error.
then we can take a look and provide some feedback.[/quote]
Sorry for the delay, my daughter was born last week so been a bit busy.
360kB 1447X1080 http://www.phoenixhosting.biz/forumpics/MK124FrontL.jpg
346kB 1467X1080 http://www.phoenixhosting.biz/forumpics/MK124BackL.jpg
Hi Res
2.84MB 2763X2062 http://www.phoenixhosting.biz/forumpics/MK124FrontH.jpg
3.06MB 2882X2122 http://www.phoenixhosting.biz/forumpics/MK124BackH.jpg
Congrats with your little baby girl!
Overall soldering looks OK, however some joint might need rework.
Also, make sure to look for damaged tracks/pads.
A fully lit bottom row is related to pin 6 of the µcontroller, you might want to check that path.
The picture don’t show if the leds are positioned correctly, I assume you have checked this.
The bottom left LED was backwards. My bad; strange how bright it was.
Thanks for the clue in though.
I’ll fix and post an update.
That was the issue, all working now thanks for the help!
Happy to read that it works!
