When pulse is on, I have electric current between : 1 and 5, 4 and 5. But nothing between 2 and 3 (strange …), 2 and 4, 3 and 5.
Same thing with the 2 kits.
Ok I understand, so it is why I have no voltage (I do not know the working of a relay …).
I found a solution : I pulled out the relay and linked 2 to 5 and 3 to 4.
Please note that if you do this, you will have to be careful that you do not draw more than 100mA of current, otherwise you will destroy the transistor.
