I have built this kit and now want to mount it in a case, to use it as a camera timer for time-lapse.
Can I remote mount the LED to the outside of the case? Is it a 12 V LED?
Can I change the trim pots to std pots of the same value to mount on the case?
In addition, If I wanted to extend the interval-the pause time, could I change the value of the CI or C2? or the Pot?
What value would you suggest for a pause time of 20-60 minutes?
I was hoping for something a little more specific. I have reviewed the data sheet for the chip and the MK111 connections don’t seem to be the same so I am unable to tell which resistor is RA and which is RB as labeled in the data sheet. I’m thinkng that R1 on the MK111 could be the right one to increase to lengthen the pulse interval…?
