Hi there, i’m fairly new to electronics, however i put your MK111 kit together without to much bother. However it doesn’t appear to be working correctly i.e the LED stays on solidly regardless of where I move the potentiomitors to.
Compnents seems placed OK but it seems like some pads aren’t properly soldered.
Try to cover the whole pad with solder.
VEL337
Hi, thanks; that seems to have solved the issue. I’m hoping to connect the unit to a slide projector as a timer via a 6pin din, would you have any idea how I would attach this:
Sorry, we are not familiar with the pinout of a slide projector connector. You might want to Google for it.
